Derivation of Langevin Dynamics in a nonzero Background Flow Field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2013
We propose a derivation of a nonequilibrium Langevin dynamics for a large particle immersed in a background flow field. A single large particle is placed in an ideal gas heat bath composed of point particles that are distributed consistently with the background flow field and that interact with the large particle through elastic collisions. In the limit of small bath atom mass, the large particle dynamics converges in law to a stochastic dynamics. This derivation follows the ideas of [D. Dürr, S. Goldstein, and J. L. Lebowitz, 1981 and 1983; P. Calderoni, D. Dürr, and S. Kusuoka, 1989] and provides extensions to handle the nonzero background flow. The derived nonequilibrium Langevin dynamics is similar to the dynamics in [M. McPhie, et al., 2001]. Some numerical experiments illustrate the use of the obtained dynamic to simulate homogeneous liquid materials under flow.
hal-00680278 , version 1 (19-03-2012)
Matthew Dobson, Frédéric Legoll, Tony Lelièvre, Gabriel Stoltz. Derivation of Langevin Dynamics in a nonzero Background Flow Field. ESAIM: Mathematical Modelling and Numerical Analysis, 2013, 47 (6), pp.1583-1626. ⟨10.1051/m2an/2013077⟩. ⟨hal-00680278⟩
210 Consultations
0 Téléchargements
