A Parallel Algorithm for solving BSDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2013
We present a parallel algorithm for solving backward stochastic differential equations. We improve the algorithm proposed in Gobet Labart (2010), based on an adaptive Monte Carlo method with Picard's iterations, and propose a parallel version of it. We test our algorithm on linear and non linear drivers up to dimension 8 on a cluster of 312 CPUs. We obtained very encouraging speedups greater than 0.7.
parallel-bsde.pdf (288.41 Ko) Télécharger le fichier
hal-00680652 , version 1 (19-03-2012)
hal-00680652 , version 2 (16-01-2013)
Céline Labart, Jérôme Lelong. A Parallel Algorithm for solving BSDEs. Monte Carlo Methods and Applications, 2013, 19 (1), pp.11-39. ⟨10.1515/mcma-2013-0001⟩. ⟨hal-00680652v2⟩
503 Consultations
554 Téléchargements
