Uniform tightness for time-inhomogeneous particle systems and for conditional distributions of time-inhomogeneous diffusion processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Markov Processes And Related Fields Année : 2013
In this article, we consider time-inhomogeneous diffusive particle systems, whose particles jump from the boundary of a bounded open subset of $\R^d$, $d\geq 1$. We give a sufficient criterion for the family of empirical distributions of such systems to be uniformly tight, independently of the jump location of the particles. As an application, we show that the conditional distribution of a family of time-inhomogeneous and environment-dependent diffusions conditioned not to hit the boundary of a bounded open subset of $\R^d$ is uniformly tight.
denis_villemonais_arxiv_20120321.pdf (230.53 Ko) Télécharger le fichier
hal-00681601 , version 1 (22-03-2012)
  • HAL Id : hal-00681601 , version 1
Denis Villemonais. Uniform tightness for time-inhomogeneous particle systems and for conditional distributions of time-inhomogeneous diffusion processes. Markov Processes And Related Fields, 2013, 19 (3), pp.543 - 562. ⟨hal-00681601⟩
188 Consultations
106 Téléchargements
