Existence and stability of solitons for fully discrete approximations of the nonlinear Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2013
In this paper we study the long time behavior of a discrete approximation in time and space of the cubic nonlinear Schrödinger equation on the real line. More precisely, we consider a symplectic time splitting integrator applied to a discrete nonlinear Schrödinger equation with additional Dirichlet boundary conditions on a large interval. We give conditions ensuring the existence of a numerical soliton which is close in energy norm to the continuous soliton. Such result is valid under a CFL condition between the time and space stepsizes. Furthermore we prove that if the initial datum is symmetric and close to the continuous soliton, then the associated numerical solution remains close to the orbit of the continuous soliton for very long times.
Soliton8.pdf (677.38 Ko) Télécharger le fichier
hal-00681730 , version 1 (22-03-2012)
Dario Bambusi, Erwan Faou, Benoît Grébert. Existence and stability of solitons for fully discrete approximations of the nonlinear Schrödinger equation. Numerische Mathematik, 2013, 123, pp.461-492. ⟨10.1007/s00211-012-0491-7⟩. ⟨hal-00681730⟩
285 Consultations
292 Téléchargements
