Grid'5000: A Large Scale And Highly Reconfigurable Experimental Grid Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of High Performance Computing Applications Année : 2006
Eddy Caron
Emmanuel Jeannot
Olivier Richard
Large scale distributed systems such as Grids are difficult to study from theoretical models and simulators only. Most Grids deployed at large scale are production platforms that are inappropriate research tools because of their limited reconfiguration, control and monitoring capabilities. In this paper, we present Grid'5000, a 5000 CPU nation-wide infrastructure for research in Grid computing. Grid'5000 is designed to provide a scientific tool for computer scientists similar to the large-scale instruments used by physicists, astronomers, and biologists. We describe the motivations, design considerations, architecture, control, and monitoring infrastructure of this experimental platform. We present configuration examples and performance results for the reconfiguration subsystem.
Autre [cs.OH]
Bolze2006.pdf (264.82 Ko) Télécharger le fichier
hal-00684943 , version 1 (05-10-2022)
Paternité - Pas d'utilisation commerciale
Raphaël Bolze, Franck Cappello, Eddy Caron, Michel Daydé, Frédéric Desprez, et al.. Grid'5000: A Large Scale And Highly Reconfigurable Experimental Grid Testbed. International Journal of High Performance Computing Applications, 2006, 20 (4), pp.481-494. ⟨10.1177/1094342006070078⟩. ⟨hal-00684943⟩
10007 Consultations
123 Téléchargements
