Building Generalized Open Boundary Conditions for Fluid Dynamics Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Fluids Année : 2013
This paper deals with the design of an efficient open boundary condition (OBC) for fluid dynamics problems. Such problematics arise, for instance, when one solves a local model on a fine grid that is nested in a coarser one of greater extent. Usually the local solution $U^{\hbox{\scriptsize loc}}$ is computed from the coarse solution $U^{\hbox{\scriptsize ext}}$ thanks to an OBC formulated as $B_hU^{\hbox{\scriptsize loc}}=B_HU^{\hbox{\scriptsize ext}}$, where $B_h$ and $B_H$ are discretizations of the same differential operator ${\cal B}$ ($B_h$ being defined on the fine grid and $B_H$ on the coarse grid). In this paper we show that such an OBC cannot lead to the exact solution, and we propose a generalized formulation $B_hU^{{\hbox{\scriptsize loc}}}=B_HU^{\hbox{\scriptsize ext}}+g$, where $g$ is a correction term. When $B_h$ and $B_H$ are discretizations of a transparent operator, $g$ can be computed analytically, at least for simple equations. Otherwise we propose to approximate $g$ by a Richardson extrapolation procedure. Numerical test cases on a 1-D Laplace equation and on a 1-D shallow water system illustrate the improved efficiency of such a generalized OBC compared to usual ones.
BE_MV_OBC.pdf (368.67 Ko) Télécharger le fichier
hal-00685195 , version 1 (04-04-2012)
Eric Blayo, Véronique Martin. Building Generalized Open Boundary Conditions for Fluid Dynamics Problems. International Journal for Numerical Methods in Fluids, 2013, 71 (4), pp.506-521. ⟨10.1002/fld.3675⟩. ⟨hal-00685195⟩
248 Consultations
356 Téléchargements
