Simulation of BSDEs by Wiener Chaos Expansion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2014
Philippe Briand
  • Fonction : Auteur
  • PersonId : 859932
Céline Labart
  • Fonction : Auteur
  • PersonId : 892488
We present an algorithm to solve BSDEs based on Wiener Chaos Expansion and Picard's iterations. We get a forward scheme where the conditional expectations are easily computed thanks to chaos decomposition formulas. We use the Malliavin derivative to compute $Z$. Concerning the error, we derive explicit bounds with respect to the number of chaos and the discretization time step. We also present numerical experiments. We obtain very encouraging results in terms of speed and accuracy.
main.pdf (401.12 Ko) Télécharger le fichier
hal-00688523 , version 1 (18-04-2012)
hal-00688523 , version 2 (08-04-2013)
Philippe Briand, Céline Labart. Simulation of BSDEs by Wiener Chaos Expansion. The Annals of Applied Probability, 2014, 24 (3), pp.1129-1171. ⟨10.1214/13-AAP943⟩. ⟨hal-00688523v2⟩
465 Consultations
511 Téléchargements
