High Performance Composition Operators in Component Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Scientific numerical applications are always expecting more computing and storage capabilities to compute at finer grain and/or to integrate more phenomena in their computations. Even though, they are getting more complex to develop. However, the continual growth of computing and storage capabilities is achieved with an increase complexity of infrastructures. Thus, there is an important challenge to define programming abstractions able to deal with software and hardware complexity. An interesting approach is represented by software component models. This chapter first analyzes how high performance interactions are only partially supported by specialized component models. Then, it introduces HLCM, a component model that aims at efficiently supporting all kinds of static compositions.
ohpcocm.pdf (444.72 Ko) Télécharger le fichier
hal-00692584 , version 1 (01-05-2012)
Julien Bigot, Christian Pérez. High Performance Composition Operators in Component Models. Ian Foster, Wolfgang Gentzsch, Lucio Grandinetti, Gerhard R. Joubert. High Performance Computing: From Grids and Clouds to Exascale, 20, IOS Press, pp.182 - 201, 2011, Advances in Parallel Computing, 978-1-60750-802-1. ⟨10.3233/978-1-60750-803-8-182⟩. ⟨hal-00692584⟩
223 Consultations
139 Téléchargements
