Gabor Noise by Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2012
Bruno Galerne
  • Fonction : Auteur
  • PersonId : 924934
Ares Lagae
  • Fonction : Auteur
  • PersonId : 871640
Procedural noise is a fundamental tool in Computer Graphics. However, designing noise patterns is hard. In this paper, we present Gabor noise by example, a method to estimate the parameters of bandwidth-quantized Gabor noise, a procedural noise function that can generate noise with an arbitrary power spectrum, from exemplar Gaussian textures, a class of textures that is completely characterized by their power spectrum. More specifically, we introduce (i) bandwidth-quantized Gabor noise, a generalization of Gabor noise to arbitrary power spectra that enables robust parameter estimation and efficient procedural evaluation; (ii) a robust parameter estimation technique for quantized-bandwidth Gabor noise, that automatically decomposes the noisy power spectrum estimate of an exemplar into a sparse sum of Gaussians using non-negative basis pursuit denoising; and (iii) an efficient procedural evaluation scheme for bandwidth-quantized Gabor noise, that uses multi-grid evaluation and importance sampling of the kernel parameters. Gabor noise by example preserves the traditional advantages of procedural noise, including a compact representation and a fast on-the-fly evaluation, and is mathematically well-founded. See project page at : http://graphics.cs.kuleuven.be/publications/GLLD12GNBE/
glld_gabor_noise_by_example_preprint.pdf (2.89 Mo) Télécharger le fichier
hal-00695670 , version 1 (09-05-2012)
Bruno Galerne, Ares Lagae, Sylvain Lefebvre, George Drettakis. Gabor Noise by Example. ACM Transactions on Graphics, 2012, 31 (4), pp.Article No. 73. ⟨10.1145/2185520.2185569⟩. ⟨hal-00695670⟩
606 Consultations
772 Téléchargements
