Subspace Identification for Linear Periodically Time-varying Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, an extension of the output-only subspace identification, to the class of linear periodically time-varying (LPTV) systems, is proposed. The goal is to identify a useful information about the system’s stability using the Floquet theory which gives a necessary and sufficient condition for stability analysis. This information is retrieved from a matrix called the monodromy matrix, which is extracted by some simultaneous singular value decompositions (SVD) and from a resolution of a least squares criterion. The method is, finally, illustrated by a simulation of a model of a helicopter with a hinged-blades rotor.
Morlier_6725.pdf (484.91 Ko) Télécharger le fichier
hal-01853132 , version 1 (02-08-2018)
Ahmed Jhinaoui, Laurent Mevel, Joseph Morlier. Subspace Identification for Linear Periodically Time-varying Systems. 16th IFAC Symposium on System Identification, Jul 2012, Bruxelles, Belgium. pp.1282-1287, ⟨10.3182/20120711-3-BE-2027.00148⟩. ⟨hal-01853132⟩
259 Consultations
145 Téléchargements
