Extension of Subspace Identification to LPTV Systems: Application to Helicopters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we focus on extending the subspace identification to the class of linear periodically time-varying (LPTV) systems. The Lyapunov-Floquet transformation is first applied to the system’s state-space model in order to get the monodromy matrix (MM) and, thus, a necessary and sufficient condition for system stability. Then, given two successive covariance-driven Hankel matrices, the MM matrix is extracted by some calculus of a simultaneous singular value decomposition (SVD) and a least square optimization. The method is illustrated by a simulation application to the model of a hinged-blades helicopter.
Morlier_6731.pdf (184.05 Ko) Télécharger le fichier
hal-01853139 , version 1 (02-08-2018)
Ahmed Jhinaoui, Laurent Mevel, Joseph Morlier. Extension of Subspace Identification to LPTV Systems: Application to Helicopters. 30th International Modal Analysis Conference (IMAC), Jan 2012, Jacksonville, FL, United States. pp.425-433, ⟨10.1007/978-1-4614-2425-3_40⟩. ⟨hal-01853139⟩
222 Consultations
86 Téléchargements
