hal-00697032, version 2
Budget Constrained Resource Allocation for Non-Deterministic Workflows on a IaaS Cloud
Eddy Caron
a, 1, 2Frédéric Desprez
b, 1, 2Adrian Muresan
1, 2Frédéric Suter
c, 2, 3
N° RR-7962 (2012)
Résumé : Many scientific applications are described through workflow structures. Due to the increasing level of parallelism offered by modern computing infrastructures, workflow applications now have to be composed not only of sequential programs, but also of parallel ones. Cloud platforms bring on-demand resource provisioning and pay-as-you-go payment charging. Then the execution of a workflow corresponds to a certain budget. The current work addresses the problem of resource allocation for non-deterministic workflows under budget constraints. We present a way of transforming the initial problem into sub-problems that have been studied before. We propose two new allocation algorithms that are capable of determining resource allocations under budget constraints and we present ways of using them to address the problem at hand.
- a – Ecole Normale Supérieure de Lyon - ENS Lyon
- b – INRIA
- c – CNRS
- 1 : Laboratoire de l'Informatique du Parallélisme (LIP)
- Université de Lyon – CNRS : UMR5668 – INRIA – École Normale Supérieure - Lyon – Université Claude Bernard - Lyon I
- 2 : AVALON (LIP Lyon / Inria Grenoble Rhône-Alpes)
- CNRS : UMR5668 – INRIA – École Normale Supérieure - Lyon – Laboratoire d'informatique du Parallélisme – Université Claude Bernard - Lyon I
- 3 : Centre de Calcul de l'inst. national de phy. nucléaire et de phy. des particules (CC IN2P3)
- CNRS : USR6402 – IN2P3
- Domaine : Informatique/Calcul parallèle, distribué et partagé
- Mots-clés : resource allocation – scheduling – PTG – workflow
- Référence interne : RR-7962
- Versions disponibles : v1 (14-05-2012) v2 (21-05-2012)
- hal-00697032, version 2
- http://hal.inria.fr/hal-00697032
- oai:hal.inria.fr:hal-00697032
- Contributeur : Adrian Muresan
- Soumis le : Dimanche 20 Mai 2012, 17:05:43
- Dernière modification le : Lundi 26 Novembre 2012, 15:09:09
Documents associés
Exporter
