Evidence for Transcript Networks Composed of Chimeric RNAs in Human Cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2012
Julien Lagarde
  • Fonction : Auteur
  • PersonId : 755946
  • IdRef : 130610062
Philipp Kapranov
  • Fonction : Auteur
David Martin
Ian Bell
  • Fonction : Auteur
Erica Dumais
  • Fonction : Auteur
Alfonso Valencia
  • Fonction : Auteur
  • PersonId : 842405
Marc Vidal
Jennifer Harrow
  • Fonction : Auteur
Tim Hubbard
  • Fonction : Auteur
Adam Frankish
  • Fonction : Auteur
The classic organization of a gene structure has followed the Jacob and Monod bacterial gene model proposed more than 50 years ago. Since then, empirical determinations of the complexity of the transcriptomes found in yeast to human has blurred the definition and physical boundaries of genes. Using multiple analysis approaches we have characterized individual gene boundaries mapping on human chromosomes 21 and 22. Analyses of the locations of the 59 and 39 transcriptional termini of 492 protein coding genes revealed that for 85% of these genes the boundaries extend beyond the current annotated termini, most often connecting with exons of transcripts from other well annotated genes. The biological and evolutionary importance of these chimeric transcripts is underscored by (1) the non-random interconnections of genes involved, (2) the greater phylogenetic depth of the genes involved in many chimeric interactions, (3) the coordination of the expression of connected genes and (4) the close in vivo and three dimensional proximity of the genomic regions being transcribed and contributing to parts of the chimeric RNAs. The non-random nature of the connection of the genes involved suggest that chimeric transcripts should not be studied in isolation, but together, as an RNA network.
DjebaliS2012.pdf (1.7 Mo) Télécharger le fichier
hal-00698428 , version 1 (06-09-2012)
  • HAL Id : hal-00698428 , version 1
Sarah Djebali, Julien Lagarde, Philipp Kapranov, Vincent Lacroix, Christelle Borel, et al.. Evidence for Transcript Networks Composed of Chimeric RNAs in Human Cells. PLoS ONE, 2012, 7, pp.1-22. ⟨hal-00698428⟩
1591 Consultations
243 Téléchargements
