Automatically Securing Permission-Based Software by Reducing the Attack Surface: An Application to Android - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
A common security architecture, called the permission-based security model (used e.g. in Android and Blackberry), entails intrinsic risks. For instance, applications can be granted more permissions than they actually need, what we call a "permission gap". Malware can leverage the unused permissions for achieving their malicious goals, for instance using code injection. In this paper, we present an approach to detecting permission gaps using static analysis. Our prototype implementation in the context of Android shows that the static analysis must take into account a significant amount of platform-specific knowledge. Using our tool on two datasets of Android applications, we found out that a non negligible part of applications suffers from permission gaps, i.e. does not use all the permissions they declare.
article.pdf (183 Ko) Télécharger le fichier
hal-00700074 , version 1 (22-05-2012)
hal-00700074 , version 2 (20-03-2013)
Alexandre Bartel, Jacques Klein, Martin Monperrus, Yves Le Traon. Automatically Securing Permission-Based Software by Reducing the Attack Surface: An Application to Android. [Research Report] hal-00700074, SnT. 2012. ⟨hal-00700074v2⟩
266 Consultations
459 Téléchargements
