Improving privacy on android smartphones through in-vivo bytecode instrumentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
In this paper we claim that a widely applicable and efficient means to fight against malicious mobile Android applications is: 1) to per- form runtime monitoring 2) by instrumenting the application byte- code and 3) in-vivo, i.e. directly on the smartphone. We present a tool chain to do this and present experimental results showing that this tool chain can run on smartphones in a reasonable amount of time and with a realistic effort. Our findings also identify chal- lenges to be addressed before running powerful runtime monitoring and instrumentations directly on smartphones. We implemented two use-cases leveraging the tool chain: FineGPolicy, a fine-grained user centric permission policy system and AdRemover an adver- tisement remover. Both prototypes improve the privacy of Android systems thanks to in-vivo bytecode instrumentation.
article.pdf (238.68 Ko) Télécharger le fichier
hal-00700319 , version 1 (22-05-2012)
Alexandre Bartel, Jacques Klein, Martin Monperrus, Kevin Allix, Yves Le Traon. Improving privacy on android smartphones through in-vivo bytecode instrumentation. [Research Report] arXiv:1208.4536, University of Luxembourg. 2012. ⟨hal-00700319⟩
368 Consultations
744 Téléchargements
