Scalability Testing of the Kadeploy Cluster Deployment System using Virtual Machines on Grid'5000
In this paper, we presented experiments conducted on the Grid'5000 testbed to explore the scalability of the Kadeploy cluster deployment solution using up to 3999 KVM virtual machines hosted on up to 668 physical machines. During our largest run, we installed a 430 MB environment on 3838 virtual machines in less than 60 minutes.
kadeploy-scale2012.pdf (122.78 Ko)
Télécharger le fichier
kadeploy-scale2012-slides.pdf (1.93 Mo)
Format : Autre
