Diffusion asymptotics of a kinetic model for gaseous mixtures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2013
In this work, we investigate the asymptotic behaviour of the solutions to the non-reactive fully elastic Boltzmann equations for mixtures in the diffusive scaling. We deal with cross sections such as hard spheres or cut-off power law potentials. We use Hilbert expansions near the common thermodynamic equilibrium granted by the H-theorem. The lower-order non trivial equality obtained from the Boltzmann equations leads to a linear functional equation in the velocity variable which is solved thanks to the Fredholm alternative. Since we consider multicomponent mixtures, the classical techniques introduced by Grad cannot be applied, and we propose a new method to treat the terms involving particles with different masses. The next-order equality in the Hilbert expansion then allows to write the macroscopic continuity equations for each component of the mixture.
BGPS2.pdf (220.22 Ko) Télécharger le fichier
hal-00704952 , version 1 (06-06-2012)
hal-00704952 , version 2 (10-07-2012)
Laurent Boudin, Bérénice Grec, Milana Pavic, Francesco Salvarani. Diffusion asymptotics of a kinetic model for gaseous mixtures. Kinetic and Related Models , 2013, 6 (1), pp.137-157. ⟨10.3934/krm.2013.6.137⟩. ⟨hal-00704952v2⟩
656 Consultations
542 Téléchargements
