s'authentifier
version française rss feed
hal-00710409, version 2
Expressiveness and Data-Flow Compilation of OpenMP Streaming Programs
Antoniu Pop () a1, Albert Cohen () a1
N° RR-8001 (2012)
Résumé : We present a data-flow extension of OpenMP to express highly dynamic control and data flow over nested, dependent tasks. The language supports dynamic creation, modular composition, variable and unbounded sets of producers/consumers, separate compilation, and first-class streams. These features, enabled by our original compilation flow, allow translating high-level parallel programming patterns, like dependences arising from StarSs' array regions, or universal low-level primitives like futures. In particular, these dynamic features can be embedded efficiently and naturally into an unmanaged imperative language, avoiding the complexity and overhead of a concurrent garbage collector. We demonstrate the performance advantages of a data-flow execution model compared to more restricted task and barrier models. We also demonstrate the efficiency of our compilation and runtime algorithms for the support of complex dependence patterns arising from StarSs benchmarks.
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • Mots-clés : Data-flow computing – stream computing – parallel programming – compilation
  • Référence interne : RR-8001
  • Versions disponibles :  v1 (21-06-2012) v2 (02-07-2012)
  • hal-00710409, version 2
  • oai:hal.inria.fr:hal-00710409
  • Contributeur :
  • Soumis le : Lundi 2 Juillet 2012, 15:23:55
  • Dernière modification le : Lundi 2 Juillet 2012, 16:29:40
tous les articles de la base du CCSd...
