Semantic Indexing and Retrieval based on Formal Concept Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Semantic indexing and retrieval has become an important research area, as the available amount of information on the Web is growing more and more. In this paper, we introduce an original approach to semantic indexing and retrieval based on Formal Concept Analysis. The concept lattice is used as a semantic index and we propose an original algorithm for traversing the lattice and answering user queries. This framework has been used and evaluated on song datasets.
techincal_report_sem_idx.pdf (185.18 Ko) Télécharger le fichier
hal-00713202 , version 1 (29-06-2012)
  • HAL Id : hal-00713202 , version 1
Victor Codocedo, Ioanna Lykourentzou, Amedeo Napoli. Semantic Indexing and Retrieval based on Formal Concept Analysis. [Research Report] Inria. 2012. ⟨hal-00713202⟩
280 Consultations
376 Téléchargements
