Time optimal control for a nonholonomic system with state constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Control and Related Fields Année : 2013
The aim of this paper is to tackle the time optimal controllability of an (n+1)-dimensional nonholonomic integrator. In the optimal control problem we consider, the state variables are subject to a bound constraint. We give a full description of the optimal control and optimal trajectories are explicitly obtained. The optimal trajectories we construct, lie in a 2-dimensional plane and they are composed of arcs of circle.
Loheac_Scheid_revised.pdf (307.4 Ko) Télécharger le fichier
hal-00713280 , version 1 (29-06-2012)
hal-00713280 , version 2 (07-01-2013)
Jérôme Lohéac, Jean-François Scheid. Time optimal control for a nonholonomic system with state constraint. Mathematical Control and Related Fields, 2013, 3 (2), pp.185-208. ⟨10.3934/mcrf.2013.3.185⟩. ⟨hal-00713280v2⟩
306 Consultations
342 Téléchargements
