Frequencies in forgetful timed automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
A quantitative semantics for infinite timed words in timed automata based on the frequency of a run is introduced in [BBBS11]. Unfortunately, most of the results are obtained only for one-clock timed automata because the techniques do not allow to deal with some phenomenon of convergence between clocks. On the other hand, the notion of forgetful cycle is introduced in [BA11], in the context of entropy of timed languages, and seems to detect exactly these con- vergences. In this paper, we investigate how the notion of forgetfulness can help to extend the computation of the set of frequencies to n-clock timed automata.
Mots clés
RR-8009.pdf (552.39 Ko) Télécharger le fichier
hal-00714262 , version 1 (03-07-2012)
  • HAL Id : hal-00714262 , version 1
Amélie Stainer. Frequencies in forgetful timed automata. [Research Report] RR-8009, INRIA. 2012. ⟨hal-00714262⟩
407 Consultations
174 Téléchargements
