Multi-Class Cosegmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bottom-up, fully unsupervised segmentation remains a daunting challenge for computer vision. In the cosegmentation context, on the other hand, the availability of multiple images assumed to contain instances of the same object classes provides a weak form of supervision that can be exploited by discriminative approaches. Unfortunately, most existing algorithms are limited to a very small number of images and/or object classes (typically two of each). This paper proposes a novel energy-minimization approach to cosegmentation that can handle multiple classes and a significantly larger number of images. The proposed cost function combines spectral- and discriminative-clustering terms, and it admits a probabilistic interpretation. It is optimized using an efficient EM method, initialized using a convex quadratic approximation of the energy. Comparative experiments show that the proposed approach matches or improves the state of the art on several standard datasets.
Fichier non déposé
hal-00717448 , version 1 (12-07-2012)
  • HAL Id : hal-00717448 , version 1
Armand Joulin, Francis Bach, Jean Ponce. Multi-Class Cosegmentation. CVPR 2012 : 25th IEEE Conference on Computer Vision and Pattern Recognition, Jun 2012, Providence, United States. pp.0109. ⟨hal-00717448⟩
405 Consultations
0 Téléchargements
