A convex relaxation for weakly supervised classifiers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces a general multi-class approach to weakly supervised classification. Inferring the labels and learning the parameters of the model is usually done jointly through a block-coordinate descent algorithm such as expectation-maximization (EM), which may lead to local minima. To avoid this problem, we propose a cost function based on a convex relaxation of the soft-max loss. We then propose an algorithm specifically designed to efficiently solve the corresponding semidefinite program (SDP). Empirically, our method compares favorably to standard ones on different datasets for multiple instance learning and semi-supervised learning, as well as on clustering tasks.
Fichier non déposé
hal-00717450 , version 1 (12-07-2012)
  • HAL Id : hal-00717450 , version 1
Armand Joulin, Francis Bach. A convex relaxation for weakly supervised classifiers. ICML 2012 International Conference on Machine Learning, Jun 2012, Edinburgh, United Kingdom. pp.641. ⟨hal-00717450⟩
141 Consultations
0 Téléchargements
