Optimization with EXIT Functions of GLDPC-Staircase Codes for the BEC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In a previous work we introduced the Generalized LDPC- Staircase codes for the Binary Erasure Channel, based on LDPC-Staircase codes and Reed Solomon as component codes. In this paper we perform an asymptotic analysis, in terms of EXtrinsic Information Transfer functions and we de- rive an upper bound of the ML decoding threshold based on the area theorem. We use this analysis to study the impact of the internal LDPC-Staircase code rate on the performance, and show that the proposed Generalized LDPC-Staircase codes closely approach the channel capacity, with only a small number (E = 2, 3) of extra-repair symbols per check node.
spawc12_EXIT_function_GLDPC_Staircase_codes_final.pdf (369.89 Ko) Télécharger le fichier
hal-00719321 , version 1 (19-07-2012)
  • HAL Id : hal-00719321 , version 1
Ferdaouss Mattoussi, Valentin Savin, Vincent Roca, Bessem Sayadi. Optimization with EXIT Functions of GLDPC-Staircase Codes for the BEC. 13th IEEE International Workshop on Signal Processing Advances in Wireless Communications (SPAWC 2012), Jun 2012, CESME, Turkey. ⟨hal-00719321⟩
303 Consultations
503 Téléchargements
