Persistent random walks, variable length Markov chains and piecewise deterministic Markov processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2012
A classical random walk $(S_t,\, t\in\mathbb{N})$ is defined by $S_t:=\displaystyle\sum_{n=0}^t X_n$, where $(X_n)$ are i.i.d. When the increments $(X_n)_{n\in\mathbb{N}}$ are a one-order Markov chain, a short memory is introduced in the dynamics of $(S_t)$. This so-called ''persistent'' random walk is nolonger Markovian and, under suitable conditions, the rescaled process converges towards the integrated telegraph noise (ITN) as the time-scale and space-scale parameters tend to zero (see \cite{Herrmann-Vallois, Tapiero-Vallois, Tapiero-Vallois2}). The ITN process is effectively non-Markovian too. The aim is to consider persistent random walks $(S_t)$ whose increments are Markov chains with variable order which can be infinite. This variable memory is enlighted by a one-to-one correspondence between $(X_n)$ and a suitable Variable Length Markov Chain (VLMC), since for a VLMC the dependency from the past can be unbounded. The key fact is to consider the non Markovian letter process $(X_n)$ as the margin of a couple $(X_n,M_n)_{n\ge 0}$ where $(M_n)_{n\ge 0}$ stands for the memory of the process $(X_n)$. We prove that, under a suitable rescaling, $(S_n,X_n,M_n)$ converges in distribution towards a time continuous process $(S^0(t),X(t),M(t))$. The process $(S^0(t))$ is a semi-Markov and Piecewise Deterministic Markov Process whose paths are piecewise linear.
cchv.pdf (671.66 Ko) Télécharger le fichier
hal-00719450 , version 1 (19-07-2012)
hal-00719450 , version 2 (20-07-2012)
  • HAL Id : hal-00719450 , version 2
Peggy Cenac, Brigitte Chauvin, Samuel Herrmann, Pierre P. Vallois. Persistent random walks, variable length Markov chains and piecewise deterministic Markov processes. 2012. ⟨hal-00719450v2⟩
479 Consultations
242 Téléchargements
