On the Optimal Stopping of a One-dimensional Diffusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2013
We consider a one-dimensional diffusion which solves a stochastic differential equation with Borel-measurable coefficients in an open interval. We allow for the endpoints to be inaccessible or absorbing. Given a Borel-measurable function $r$ that is uniformly bounded away from 0, we establish a new analytic representation of the $r$-potential of a continuous additive functional of the diffusion. We also characterize the value function of an optimal stopping problem with general reward function as the unique solution of a variational inequality (in the sense of distributions) with appropriate growth or boundary conditions. Furthermore, we establish several other characterisations of the solution to the optimal stopping problem, including a generalisation of the so-called "principle of smooth fit".
Lamberton-Zervos2012.pdf (424.37 Ko) Télécharger le fichier
hal-00720149 , version 1 (23-07-2012)
Damien Lamberton, Mihail Zervos. On the Optimal Stopping of a One-dimensional Diffusion. Electronic Journal of Probability, 2013, 18 (34), pp.1-49. ⟨10.1214/EJP.v18-2182⟩. ⟨hal-00720149⟩
219 Consultations
353 Téléchargements
