JellyLens: Content-Aware Adaptive Lenses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cyprien Pindat
  • Fonction : Auteur correspondant
  • PersonId : 928363
Connectez-vous pour contacter l'auteur
Emmanuel Pietriga
Olivier Chapuis
Claude Puech
  • Fonction : Auteur
  • PersonId : 928364
Focus+context lens-based techniques smoothly integrate two levels of detail using spatial distortion to connect the magnified region and the context. Distortion guarantees visual continuity, but causes problems of interpretation and focus targeting, partly due to the fact that most techniques are based on statically-defined, regular lens shapes, that result in far-from-optimal magnification and distortion. JellyLenses dynamically adapt to the shape of the objects of interest, providing detail-in-context visualizations of higher relevance by optimizing what regions fall into the focus, context and spatially-distorted transition regions. This both improves the visibility of content in the focus region and preserves a larger part of the context region. We describe the approach and its implementation, and report on a controlled experiment that evaluates the usability of JellyLenses compared to regular fisheye lenses, showing clear performance improvements with the new technique for a multi-scale visual search task.
jelly-lenses-hal.pdf (1.91 Mo) Télécharger le fichier
jelly-lenses-UIST2012.mov (37.78 Mo) Télécharger le fichier
Format : Figure, Image
hal-00721574 , version 1 (27-07-2012)
Cyprien Pindat, Emmanuel Pietriga, Olivier Chapuis, Claude Puech. JellyLens: Content-Aware Adaptive Lenses. UIST 2021 - 25th Symposium on User Interface Software and Technology, ACM, Oct 2012, Cambridge, Massachusetts, United States. pp.261-270, ⟨10.1145/2380116.2380150⟩. ⟨hal-00721574⟩
739 Consultations
832 Téléchargements
