Toward Multilevel Textual Requirements Traceability Using Model-Driven Engineering and Information Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In complex industrial projects, textual information remains the main vector of information at the project level. Consequently, requirements are scattered throughout multiple documents expressing different levels of requirements and different kinds of requirements. Formalizing this information and tracing different relationships among documents and organizing this environment present a challenging question. Domain-specific modeling and traceability modeling are Model-Driven Engineering (MDE) techniques that could address various aspects of requirements formalization. Text-based high level requirements can be formalized as document concepts can be gathered and represented. Still, relationships cannot always be determined using sole MDE approaches and, as a consequence, relationships and traceability issue remains. Information retrieval (IR) approaches have already proved to work in an efficient way on large text corpora for requirements traceability analysis but do only consider similarity aspects of flatten documents, losing their organization and hierarchy. This paper aims to introduce how a combined use of both MDE and IR can lead to improved requirements organization and traceability while handling textual ambiguous requirements documents.
Dans les projets industriels complexes, le texte reste le principal vecteur d'information au niveau du projet. Les exigences sur le futur système sont ainsi disséminées à travers de nombreux documents qui expriment différents niveaux d'exigences et différentes sortes d'exigences. Formaliser cette information et tracer les relations entre ces documents et organiser un un tel environnement représente un défi important. La modélisation d'un domaine ou de la traçabilité dans ce domaine sont des contributions de l'ingénierie dirigée par les modèles (IDM) pour formaliser de tels ensembles. Des exigences textuelles de haut niveau peuvent être formalisées tandis que les documents qui les contiennent peuvent être importés et analysés. Cependant, les relations de traçabilité, elles, ne peuvent pas forcément être acquises à travers ces seules techniques provenant de l'IDM. D'un autre côté, les techniques de recherche d'information (RI) ont déjà démontré leur efficacité sur de larges collections de textes pour la traçabilité des exigences mais ne considèrent que des versions "planes" des documents, perdant toute la hiérarchie et l'organisation de ceux ci. Cet article vise à introduire l'utilisation combiné de l'IDM et de la RI afin d'améliorer les aspects structurels et traçabilité de ces collections de documents d'exigences.
MoDRE2012_Sannier_Baudry_Multilevel_Requirements_Traceability_Using_MDE_and_IR-cr3.pdf (628.17 Ko) Télécharger le fichier
hal-00721806 , version 1 (30-07-2012)
  • HAL Id : hal-00721806 , version 1
Nicolas Sannier, Benoit Baudry. Toward Multilevel Textual Requirements Traceability Using Model-Driven Engineering and Information Retrieval. Second International Model-Driven Requirements Engineering (MoDRE) Workshop, Sep 2012, Chicago, United States. ⟨hal-00721806⟩
218 Consultations
413 Téléchargements
