hal-00723365, version 2
Sharp analysis of low-rank kernel matrix approximations
(2012)
Résumé : We consider supervised learning problems within the positive-definite kernel framework, such as kernel ridge regression, kernel logistic regression or the support vector machine. With kernels leading to infinite-dimensional feature spaces, a common practical limiting difficulty is the necessity of computing the kernel matrix, which most frequently leads to algorithms with running time at least quadratic in the number of observations n, i.e., O(n^2). Low-rank approximations of the kernel matrix are often considered as they allow the reduction of running time complexities to O(p^2 n), where p is the rank of the approximation. The practicality of such methods thus depends on the required rank p. In this paper, we show that for approximations based on a random subset of columns of the original kernel matrix, the rank p may be chosen to be linear in the degrees of freedom associated with the problem, a quantity which is classically used in the statistical analysis of such methods, and is often seen as the implicit number of parameters of non-parametric estimators. This result enables simple algorithms that have sub-quadratic running time complexity, but provably exhibit the same predictive performance than existing algorithms, for any given problem instance, and not only for worst-case situations.
- 1 : SIERRA (INRIA Paris - Rocquencourt)
- INRIA : PARIS - ROCQUENCOURT – Ecole normale supérieure de Paris - ENS Paris – CNRS : UMR8548
- 2 : Laboratoire d'informatique de l'école normale supérieure (LIENS)
- CNRS : UMR8548 – Ecole normale supérieure de Paris - ENS Paris
- Domaine : Informatique/Apprentissage
Mathématiques/Statistiques
Statistiques/Théorie - Versions disponibles : v1 (09-08-2012) v2 (09-02-2013)
- hal-00723365, version 2
- http://hal.archives-ouvertes.fr/hal-00723365
- oai:hal.archives-ouvertes.fr:hal-00723365
- Contributeur : Francis Bach
- Soumis le : Vendredi 8 Février 2013, 16:45:36
- Dernière modification le : Samedi 9 Février 2013, 12:11:21
Documents associés
Exporter
