LU factorization with panel rank revealing pivoting and its communication avoiding version - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
Amal Khabou
  • Fonction : Auteur
  • PersonId : 918056
James W. Demmel
  • Fonction : Auteur
  • PersonId : 849003
Laura Grigori
Ming Gu
  • Fonction : Auteur
  • PersonId : 918057
We present the LU decomposition with panel rank revealing pivoting (LU_PRRP), an LU factorization algorithm based on strong rank revealing QR panel factorization. LU_PRRP is more stable than Gaussian elimination with partial pivoting (GEPP). Our extensive numerical experiments show that the new factorization scheme is as numerically stable as GEPP in practice, but it is more resistant to pathological cases and easily solves the Wilkinson matrix and the Foster matrix. We also present CALU_PRRP, a communication avoiding version of LU_PRRP that minimizes communication. CALU_PRRP is based on tournament pivoting, with the selection of the pivots at each step of the tournament being performed via strong rank revealing QR factorization. CALU_PRRP is more stable than CALU, the communication avoiding version of GEPP. CALU_PRRP is also more stable in practice and is resistant to pathological cases on which GEPP and CALU fail.
RR-7867.pdf (1 Mo) Télécharger le fichier
hal-00723564 , version 1 (10-08-2012)
Amal Khabou, James W. Demmel, Laura Grigori, Ming Gu. LU factorization with panel rank revealing pivoting and its communication avoiding version. [Research Report] RR-7867, INRIA. 2012. ⟨hal-00723564⟩
209 Consultations
202 Téléchargements
