A looped-functional approach for robust stability analysis of linear impulsive systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2012
A new functional-based approach is developed for the stability analysis of linear impulsive systems. The new method, which introduces looped-functionals, considers non-monotonic Lyapunov functions and leads to LMIs conditions devoid of exponential terms. This allows one to easily formulate dwell-times results, for both certain and uncertain systems. It is also shown that this approach may be applied to a wider class of impulsive systems than existing methods. Some examples, notably on sampled-data systems, illustrate the efficiency of the approach.
hal-00724545 , version 1 (21-08-2012)
Corentin Briat, Alexandre Seuret. A looped-functional approach for robust stability analysis of linear impulsive systems. Systems and Control Letters, 2012, 61 (10), pp.980-988. ⟨10.1016/j.sysconle.2012.07.008⟩. ⟨hal-00724545⟩
814 Consultations
0 Téléchargements
