Algorithm for identification of piecewise smooth hybrid systems: application to Eukaryotic Cell Cycle regulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
We discuss piecewise smooth hybrid systems as models for regulatory networks in molecular biology. These systems involve both continuous and discrete variables. The discrete variables allow to switch on and off some of the molecular interactions in the model of the biological system. Piecewise smooth hybrid models are well adapted to approximate the dynamics of multiscale dissipative systems that occur in molecular biology. We show how to produce such models by a top down approach that use biological knowledge for a guided choice of important variables and interactions. Then we propose an algorithm for fitting parameters of the piecewise smooth models from data. We illustrate some of the possibilities of this approach by proposing hybrid versions of eukaryotic cell cycle regulation.
hal-00725282 , version 1 (24-08-2012)
Vincent Noël, Sergey A. Vakulenko, Ovidiu Radulescu. Algorithm for identification of piecewise smooth hybrid systems: application to Eukaryotic Cell Cycle regulation. Teresa Przytycka, Marie-France Sagot. Algorithms in Bioinformatics, Springer, pp.225-236, 2011, Lecture Notes in Computer Science, vol. 6833, 9783642230370. ⟨10.1007/978-3-642-23038-7_20⟩. ⟨hal-00725282⟩
163 Consultations
0 Téléchargements
