Effective construction of divergence-free wavelets on the square - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2013
We present an effective construction of divergence-free wavelets on the square, with suitable boundary conditions. Since 2D divergence-free vector functions are the curl of scalar stream-functions, we simply derive divergence-free multiresolution spaces and wavelets by considering the curl of standard biorthogonal multiresolution analyses (BMRAs) on the square. The key point of the theory is that the derivative of a 1D BMRA is also a BMRA, as established by Jouini and Lemari'e-Rieusset [11]. We propose such construction in the context of generic compactly supported wavelets, which allows fast algorithms. Examples illustrate the practicality of the method.
articleJCAM.pdf (608.7 Ko) Télécharger le fichier
hal-00727038 , version 1 (31-08-2012)
Souleymane Kadri Harouna, Valérie Perrier. Effective construction of divergence-free wavelets on the square. Journal of Computational and Applied Mathematics, 2013, 240, pp.74-86. ⟨10.1016/j.cam.2012.07.029⟩. ⟨hal-00727038⟩
428 Consultations
203 Téléchargements
