Toward a higher-level visual representation for content-based image retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multimedia Tools and Applications Année : 2012
Ismail Elsayad
  • Fonction : Auteur
Jean Martinet
Thierry Urruty
SIC
Chabane Djeraba
Having effective methods to access the desired images is essential nowadays with the availability of a huge amount of digital images. The proposed approach is based on an analogy between content-based image retrieval and text retrieval. The aim of the approach is to build a meaningful mid-level representation of images to be used later on for matching between a query image and other images in the desired database. The approach is based firstly on constructing different visual words using local patch extraction and fusion of descriptors. Secondly, we introduce a new method using multilayer pLSA to eliminate the noisiest words generated by the vocabulary building process. Thirdly, a new spatial weighting scheme is introduced that consists of weighting visual words according to the probability of each visual word to belong to each of the n Gaussian. Finally, we construct visual phrases from groups of visual words that are involved in strong association rules. Experimental results show that our approach outperforms the results of traditional image retrieval techniques.
JournalMTAP.pdf (694.58 Ko) Télécharger le fichier
hal-00876204 , version 1 (24-10-2013)
Ismail Elsayad, Jean Martinet, Thierry Urruty, Chabane Djeraba. Toward a higher-level visual representation for content-based image retrieval. Multimedia Tools and Applications, 2012, 60 (2), pp.455-482. ⟨10.1007/s11042-010-0596-x⟩. ⟨hal-00876204⟩
305 Consultations
395 Téléchargements
