Diagnosys: Automatic Generation of a Debugging Interface to the Linux Kernel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Linux kernel does not export a stable, well-defined kernel interface, complicating the development of kernel-level services, such as device drivers and file systems. While there does exist a set of functions that are exported to external modules, this set of functions frequently changes, and the functions have implicit, ill-documented preconditions. No specific debugging support is provided. We present \textit{Diagnosys}, an approach to automatically constructing a debugging interface for the Linux kernel. First, a designated kernel maintainer ses Diagnosys to identify constraints on the use of the exported functions. Based on this information, developers of kernel services can then use Diagnosys to generate a debugging interface specialized to their code. When a service including this interface is tested, it records information about potential problems. This information is preserved following a kernel crash or hang. Our experiments show that the generated debugging interface provides useful log information and incurs a low performance penalty.
diagnosys-ase12.pdf (253.71 Ko) Télécharger le fichier
hal-00731064 , version 1 (12-09-2012)
Tegawendé F. Bissyandé, Laurent Réveillère, Julia L. Lawall, Gilles Muller. Diagnosys: Automatic Generation of a Debugging Interface to the Linux Kernel. 27th IEEE/ACM International Conference on Automated Software Engineering, Sep 2012, Essen, Germany. pp.60-69, ⟨10.1145/2351676.2351686⟩. ⟨hal-00731064⟩
365 Consultations
491 Téléchargements
