How To Avoid Biases In Reactive Simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In order to ensure simulations reproducibility, particular attention must be payed to the specification of its model. This requires adequate design methodologies, that enlightens modelers on possible implementation ambiguities - and biases - their model might have. Yet, because of not adapted knowledge representation, current reactive simulation design methodologies lack specifications concerning interaction selection, especially in stochastic behaviors. Thanks to the interaction-oriented methodology IODA - which knowledge representation is fit to handle such problems - this paper provides simple guidelines to describe interaction selection. These guidelines use a subsumption like-structure, and focus the design of interaction selection on two points: how the selection takes place - for instance first select the interaction, and then select the partner of the interaction, or first a partner and then an interaction - and the nature of each selection - for instance at random, or with a utility function. This provides a valuable communication support between modelers and computer scientists, that makes the interpretation of the model and its implementation clearer, and the identification of ambiguities and biases easier.
KUBERA_PAAMS09.PDF (70.84 Ko) Télécharger le fichier
hal-00732046 , version 1 (29-10-2013)
  • HAL Id : hal-00732046 , version 1
Yoann Kubera, Philippe Mathieu, Sébastien Picault. How To Avoid Biases In Reactive Simulations. 7th International conference on Practical Applications of Agents and Multi-Agents Systems (PAAMS'2009), Mar 2009, Salamanca, Spain. pp.100-109. ⟨hal-00732046⟩
118 Consultations
238 Téléchargements
