Minimal time control of fed-batch bioreactor with product inhibition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioprocess and Biosystems Engineering Année : 2013
This paper is devoted to the minimal time control problem for fed-batch bioreactors, in presence of an inhibitory product, which is released by the biomass proportionally to its growth. We first consider a growth rate with substrate saturation and product inhibition, and we prove that the optimal strategy is fill and wait (bang-bang). We then investigate the case of the Jin growth rate which takes into account substrate and product inhibition. For this type of growth function, we can prove the existence of singular arc paths defining singular strategies. Several configurations are addressed depending on the parameter set. For each case, we provide an optimal feedback control of the problem (of type bang-bang or bang-singular-bang). These results are obtained gathering the initial system into a planar one by using conservation laws. Thanks to Pontryagin maximum principle, Green's theorem, and properties of the switching function, we obtain the optimal synthesis. A methodology is also proposed in order to implement the optimal feeding strategies.
InhibitionHal.pdf (393.07 Ko) Télécharger le fichier
hal-00734225 , version 1 (21-09-2012)
Copyright (Tous droits réservés)
Térence Bayen, Francis Mairet. Minimal time control of fed-batch bioreactor with product inhibition. Bioprocess and Biosystems Engineering, 2013, 36 (10), pp.1485-1496. ⟨10.1007/s00449-013-0911-9⟩. ⟨hal-00734225⟩
478 Consultations
475 Téléchargements
