Reachability of Delayed Hybrid Systems Using Level-set Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study proposes an algorithm to synthesize controllers for the power management on board hybrid vehicles that allows the vehicle to reach its maximum range along a given route. The algorithm stems from a level-set approach that computes the reachable set of the system, i.e., the collection of states reachable from a certain initial condition via the computation of the value function of an optimal control problem. The discrete-time vehicle model is one of a particular class of hybrid vehicles, namely, range extender electric vehicles (REEV). This kind of hybridization departures from a full electric vehicle that has an additional module -- the range extender (RE) -- as an extra energy source in addition to its main energy source -- a high voltage battery. As an important feature, our model allows for the switching on and off of the range extender and includes a decision lag constraint, i.e., imposes two consecutive switches to be separated by a positive time interval. The approach consists in the introduction of an adequate optimal control problem with lag constraints on the switch control whose value function allows a characterization of the reachable set. The value function is in turn characterized by a dynamic programming algorithm. This algorithm is implemented and some numerical examples are presented.
ENGOPT_2K12.pdf (386.41 Ko) Télécharger le fichier
hal-00735660 , version 1 (26-09-2012)
Giovanni Granato. Reachability of Delayed Hybrid Systems Using Level-set Methods. 3rd International Conference on Engineering Optimization, Jul 2012, Rio de Janeiro, Brazil. ⟨hal-00735660⟩
176 Consultations
111 Téléchargements
