On the Influence of the Algebraic Degree of $F^{-1}$ on the Algebraic Degree of G ∘ F - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2013
We present a study on the algebraic degree of iterated permutations seen as multivariate polynomials. The main result shows that this degree depends on the algebraic degree of the inverse of the permutation which is iterated. This result is also extended to non-injective balanced vectorial functions where the relevant quantity is the minimal degree of the inverse of a permutation expanding the function. This property has consequences in symmetric cryptography since several attacks or distinguishers exploit a low algebraic degree, like higher-order di erential attacks, cube attacks and cube testers, or algebraic attacks. Here, we present some applications of this improved bound to a higherdegree variant of the block cipher KN, to the block cipher Rijndael-256 and to the inner permutations of the hash functions ECHO and JH.
ieee_boura_canteaut.pdf (420.67 Ko) Télécharger le fichier
hal-00738398 , version 1 (04-10-2012)
Christina Boura, Anne Canteaut. On the Influence of the Algebraic Degree of $F^{-1}$ on the Algebraic Degree of G ∘ F. IEEE Transactions on Information Theory, 2013, 59 (1), pp.691-702. ⟨10.1109/TIT.2012.2214203⟩. ⟨hal-00738398⟩
Collections
INRIA INRIA2
163 Consultations
351 Téléchargements
