Non-parametric Density Modeling and Outlier Detection in Medical Imaging Datasets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The statistical analysis of medical images is challenging because of the high dimensionality and low signal-to-noise ratio of the data. Simple parametric statistical models, such as Gaussian distributions, are well-suited to high-dimensional settings. In practice, on medical data made of heterogeneous subjects, the Gaussian hypothesis seldom holds. In addition, alternative parametric models of the data tend to break down due to the presence of outliers that are usually removed manually from studies. Here we focus on interactive detection of these outlying observations, to guide the practitioner through the data inclusion process. Our contribution is to use Local Component Analysis as a non-parametric density estimator for this purpose. Experiments on real and simulated data show that our procedure separates well deviant observations from the relevant and representative ones. We show that it outperforms state-of-the-art approaches, in particular those involving a Gaussian assumption.
camera_ready.pdf (237.41 Ko) Télécharger le fichier
hal-00738438 , version 1 (04-10-2012)
  • HAL Id : hal-00738438 , version 1
Virgile Fritsch, Gaël Varoquaux, Jean-Baptiste Poline, Bertrand Thirion. Non-parametric Density Modeling and Outlier Detection in Medical Imaging Datasets. Machine Learning in Medical Imaging - Miccai 2012 workshop, Oct 2012, Nice, France. pp.207-214. ⟨hal-00738438⟩
274 Consultations
468 Téléchargements
