Weak second order explicit stabilized methods for stiff stochastic differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2013
We introduce a new family of explicit integrators for stiff Itô stochastic differential equations (SDEs) of weak order two. These numerical methods belong to the class of one-step stabilized methods with extended stability domains and do not suffer from the stepsize reduction faced by standard explicit methods. The family is based on the standard second order orthogonal Runge-Kutta Chebyshev methods (ROCK2) for deterministic problems. The convergence, and the mean-square and asymptotic stability properties of the methods are analyzed. Numerical experiments, including applications to nonlinear SDEs and parabolic stochastic partial differential equations are presented and confirm the theoretical results.
paper_srock2.pdf (1.09 Mo) Télécharger le fichier
hal-00739754 , version 1 (08-10-2012)
hal-00739754 , version 2 (11-04-2013)
Assyr Abdulle, Gilles Vilmart, Konstantinos Zygalakis. Weak second order explicit stabilized methods for stiff stochastic differential equations. SIAM Journal on Scientific Computing, 2013, 35 (4), pp.1792-1814. ⟨10.1137/12088954X⟩. ⟨hal-00739754v2⟩
269 Consultations
343 Téléchargements
