Immersed boundary methods for the numerical simulation of incompressible aerodynamic and fluid-structure interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Mathématiques Blaise Pascal Année : 2013
In this work three branches of Immersed Boundary Methods (IBM) are described and validated for incompressible aerodynamics and fluid-structure interactions. These three approaches are: Cut Cell method, Vortex-Penalization method and Forcing method. Two first techniques are validated for external bluff-body flows and the last one is used for fluid-structure interactions. The paper confirms the ability of this family of numerical schemes for accurate and robust simulation of incompressible flows.
article.pdf (574.63 Ko) Télécharger le fichier
hal-00741217 , version 1 (12-10-2012)
Nicolas James, Emmanuel Maitre, Iraj Mortazavi. Immersed boundary methods for the numerical simulation of incompressible aerodynamic and fluid-structure interactions. Annales Mathématiques Blaise Pascal, 2013, 20 (1), pp.139-173. ⟨10.5802/ambp.324⟩. ⟨hal-00741217⟩
425 Consultations
669 Téléchargements
