Qualitative identification of cracks using 3D transient elastodynamic topological derivative: formulation and FE implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2013
A time-domain topological derivative (TD) approach is developed for transient elastic-wave imaging of buried cracks. The TD, which quantifies the sensitivity of the misfit cost functional to the creation at a specified location of an infinitesimal trial crack, is expressed in terms of the time convolution of the free field and an adjoint field as a function of that specified location and of the trial crack shape. Following previous studies on cavity identification in similar conditions, the TD field is here considered as a natural and computationally efficient approach for defining a crack location indicator function. This study emphasizes the implementation and exploitation of TD fields using the standard displacement-based FEM, a straightforward exploitation of the relevant sensitivity formulation established here. Results on several numerical experiments on 3D elastodynamic and acoustic configurations are reported and discussed, allowing to assess and highlight many features of the proposed TD-based fast qualitative crack identification, including its ability to identify multiple cracks and its robustness against data noise.
cmame12_td.pdf (22.71 Mo) Télécharger le fichier
hal-00741515 , version 1 (13-10-2012)
Cédric Bellis, Marc Bonnet. Qualitative identification of cracks using 3D transient elastodynamic topological derivative: formulation and FE implementation. Computer Methods in Applied Mechanics and Engineering, 2013, 253, pp.89-105. ⟨10.1016/j.cma.2012.10.006⟩. ⟨hal-00741515⟩
411 Consultations
237 Téléchargements
