More testable properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal on Software Tools for Technology Transfer Année : 2012
Testing remains a widely used validation technique for software systems. However, recent needs in software development (e.g., in terms of security concerns) may require to extend this technique to address a larger set of properties. In this article, we explore the set of testable properties within the Safety-Progress classification where testability means to establish by testing that a relation, between the tested system and the property under scrutiny, holds. We characterize testable properties w.r.t. several relations of interest. For each relation, we give a sufficient condition for a property to be testable. Then, we study and delineate a fine-grain characterization of testable properties: for each Safety-Progress class, we identify the subset of testable properties and their corresponding test oracle. Furthermore, we address automatic test generation for the proposed framework by providing a general synthesis technique that allows to obtain canonical testers for the testable properties in the Safety-Progress classification. Moreover, we show how the usual notion of quiescence can be taken into account in our general framework, and, how quiescence improves the testability results. Then, we list some existing testing approaches that could benefit from this work by addressing a wider set of properties. Finally, we propose Java-PT, a prototype Java toolbox that implements the results introduced in this article.
STTT-ICTSS10-preprint.pdf (1.16 Mo) Télécharger le fichier
hal-00743981 , version 1 (22-10-2012)
Yliès Falcone, Jean-Claude Fernandez, Thierry Jéron, Hervé Marchand, Laurent Mounier. More testable properties. International Journal on Software Tools for Technology Transfer, 2012, 14 (4), pp.407-437. ⟨10.1007/s10009-011-0220-z⟩. ⟨hal-00743981⟩
327 Consultations
183 Téléchargements
