A Robust Access Protocol for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper introduces a family of periodic binary sequences with interesting cross-correlation properties for potential applications in distributed wireless accessing. Following Massey's model of collision channel without feedback, a simple and robust multiple access protocol that does not require complicated processing such as back-off algorithms or random number generation is proposed for wireless sensor and ad hoc networks. In addition, energy-efficient data reception is achievable by the protocol while continuous channel listening can be eliminated. Besides, a simple predictive collision avoidance scheme is presented for the enhancement of system throughput. Simulation studies are carried out to show its effectiveness.
A_robust_access_protocol_for_wireless_sensor_networks.pdf (159.47 Ko) Télécharger le fichier
hal-00745049 , version 1 (24-10-2012)
Chung Shue Chen, Wing Shing Wong. A Robust Access Protocol for Wireless Sensor Networks. IEEE Military Communications Conference, IEEE, Oct 2006, Washington, D.C., United States. ⟨10.1109/MILCOM.2006.302456⟩. ⟨hal-00745049⟩
172 Consultations
164 Téléchargements
