Experimental Setup for Human Aware Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2012
Validation of algorithms developed by assistance robotics research on real platforms is essential. Producing robotic architectures that promote scientific advances while regarding usability for the final user is a challenging issue where an appropriate trade-off between both requirements must be found. This paper proposes a new framework for the development of mobility assistance techniques to improve the quality of life of elder population using a robotic wheelchair. An example of improvement of the wheelchair navigation is presented. The control of the wheelchair is done using a Bayesian semi-autonomous approach that estimates the user intended destination from input commands given through a Kinect sensor. Safe and comfortable autonomous navigation is performed using a probabilistic navigation method that takes into account the dynamics of the environment and human social conventions.
Escobedo_CAR2012.pdf (393.45 Ko) Télécharger le fichier
hal-00746567 , version 1 (29-10-2012)
  • HAL Id : hal-00746567 , version 1
Arturo Escobedo, Anne Spalanzani, Christian Laugier. Experimental Setup for Human Aware Navigation. Control Architectures of Robots, May 2012, Nancy, France. ⟨hal-00746567⟩
294 Consultations
345 Téléchargements
