s'authentifier
version française rss feed
hal-00747002, version 1
Routing based Roles Assignment for Monitoring 6LowPAN Networks
Abdelkader Lahmadi (, http://www.loria.fr/~lahmadi) 1, Laurent Ciarletta () 1, Alexandre Boeglin () 1, Olivier Festor () 1
Third International Conference on Communications and Networking (ComNet) (2012)
Résumé : In this work, we present a novel approach to assign monitoring roles in constrained, low power and lossy networks using available local information provided by the routing layer. The resulting monitoring architecture is adaptive taking benefit from the reactivity of the routing protocol when dynamic changes occur due to connectivity or nodes movement. The simulation results reveal that our assignment approach is more efficient, less aggressive and less resources consuming than its competitors.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : Communication system security – Computer architecture – Monitoring – Routing – Routing protocols – Wireless sensor networks
  • hal-00747002, version 1
  • oai:hal.inria.fr:hal-00747002
  • Contributeur :
  • Soumis le : Mardi 30 Octobre 2012, 11:58:04
  • Dernière modification le : Mardi 30 Octobre 2012, 13:53:49
tous les articles de la base du CCSd...
