Curvilinear schemes and maximum rank of forms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We define the \emph{curvilinear rank} of a degree $d$ form $P$ in $n+1$ variables as the minimum length of a curvilinear scheme, contained in the $d$-th Veronese embedding of $\mathbb{P}^n$, whose span contains the projective class of $P$. Then, we give a bound for rank of any homogenous polynomial, in dependance on its curvilinear rank.
lanostraquestion.pdf (110.37 Ko) Télécharger le fichier
hal-00747023 , version 1 (30-10-2012)
Edoardo Ballico, Alessandra Bernardi. Curvilinear schemes and maximum rank of forms. 2012. ⟨hal-00747023⟩
144 Consultations
119 Téléchargements
