hal-00748243, version 1
Opacité dans les systèmes workflows
Eric Badouel
1Lamine Mohamadou Diouf
a, 1
CARI - 11th African Conference on Research in Computer Science and Applied Mathematics (2012)
Résumé : A property (of an object) is opaque to an observer when he or she cannot deduce the property from its set of observations. If each observer is attached to a given set of properties (the so-called secrets), then the system is said to be opaque if each secret is opaque to the corresponding observer. Opacity has been studied in the context of discrete event dynamic systems where technique of control theory were designed to enforce opacity. To the best of our knowledge, this paper is the first attempt to formalize opacity of artifacts in data-centric workflow systems. We motivate this problem and give some assumptions that guarantee the decidability of opacity. The techniques for enforcing opacity are left as a direction for further work.
- a – Inria
- 1 : S4 (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – Institut National des Sciences Appliquées (INSA) - Rennes – Université de Rennes 1
- Domaine : Informatique/Théorie et langage formel
- Mots-clés : Opacity – data-centric workflow systems – artifact – structured documents
- hal-00748243, version 1
- http://hal.inria.fr/hal-00748243
- oai:hal.inria.fr:hal-00748243
- Contributeur : Eric Badouel
- Soumis le : Lundi 5 Novembre 2012, 11:23:08
- Dernière modification le : Jeudi 14 Février 2013, 09:17:17
Documents associés
Exporter
