A satellite imaging chain based on the Compressed Sensing technique
Satellite imaging has been the focus of intense works in remote sensing for the last years. The ability of satellite optical systems to produce high-resolution images has indeed been of a great interest in applications such as change detection or image classification. The design of a satellite acquisition chain is however quite challenging as it involves expensive processes such as sampling and coding. In this work, we investigate the performances of a low-resource satellite imaging chain based on the Compressed Sensing (CS) acquisition technique. We propose a reconstruction algorithm which takes into account the degradations of the satellite imaging chain and we present results on a real satellite data.
Traitement des images [eess.IV]
